Open Loop Mode in MCSDK
‎2023-05-03 9:52 AM
I have seen the following options in the software in MCSDK
MCI_CMD_SETOPENLOOPCURRENT, /*!< set open loop current .*/
MCI_CMD_SETOPENLOOPVOLTAGE, /*!< set open loop voltage .*/
in mc_interface.h file, but i don't see any source code related to them does MCSDK support open loop mode? I need them to rectify some of the hardware issues, before i run in closed loop with hall sensors. Please advise.
STM32 Motor Control
‎2023-05-12 1:08 AM
Duty Cycle = 10
OL_UpdateVoltage( &OpenLoop_ParamsM1, ((10 * 32767) / 100));
Speed = 100
MCI_ExecSpeedRamp(&Mci[MOTOR_0], (int16_t)((100 * SPEED_UNIT) / U_RPM), 1000);
Duration is 1000.
I am not sure the below is also impacting
OpenLoop_Handle_t OpenLoop_ParamsM1 =
.hDefaultVoltage = OPEN_LOOP_VOLTAGE_d,
.VFMode = OPEN_LOOP_VF,
.hVFOffset = OPEN_LOOP_OFF,
.hVFSlope = OPEN_LOOP_K
#define OPEN_LOOP_VOLTAGE_d 2000 /*!< Three Phase voltage amplitude in int16_t format */
#define OPEN_LOOP_VF false
I am also checking on the hardware side in parallel. Could you please tell me any other changes i need to check or any signal i can verify to confirm?
I have attached the motor data sheet i have the Battery voltage at 20V.
‎2023-05-12 3:59 AM
Thank you it runs now after correcting hardware issues, but few concerns is after some rotations for 1 to 2 minutes it gets struck up, sometimes gets problem in starting. Do we have solutions for that?
‎2023-05-18 1:42 AM
Now I have landed in confusion when you give the last command Mci_execSpeedRamp it does not stay in open loop mode it goes to speed mode, could you please explain me this?​
‎2023-05-21 9:08 AM - edited ‎2023-11-20 6:34 AM
It is my mistake
- « Previous
- 1
- 2
- Next »
