2024-03-04 07:00 AM
I'm having following issue with the Motor Pilot that comes with the MCSDK 6.2.1 (V1.2.5).
I try to modify the Rev-up phase configuration.
Now when I write a torque value in any of the phases, this value resets to zero and is saved on the board (pressing "Read parameters" returns the zero values). If that happens, I cannot set it to any other value until I power-cycle the board, in which case it resets to the values predefined in firmware.
Any way to make this feature usable again?
2024-05-17 12:46 AM
Hello DMeie.2,
Have you tried our latest MCSDK 6.3.0 release ? Can you confirm that you still experience the issue on the latest MotorPilot ?
2024-05-17 02:09 AM
I was not aware there's a new MCSDK release.
I will give it a try and report back.
Is there a way to subscribe anywhere to get notified about new releases?
