2025-01-21 6:52 AM
I am trying to control a 24V PMSM type motor using ST Motor Control Workbench version 6.3.1 with the FOC. I use the position control method as the control method. Tuning PID parameter is given in AN5464.
Although i tried to tune the PID parameters manually in accordance with demonstration code given in AN5464, par. 5.8, motor starting to oscillate when i try to rotate motor in multi-turn (for example 4-turn, 8 * PI radian). So i am trying to use a software tool like STM32CubeMonitor in order to tune PID parameters.
I have the following questions:
Any information you can provide will be appreciated.
2025-04-16 1:50 AM
Hello @EDokm,
Firstly, we would like to apologize for the delay in replying to your post.
Refer to User Manual documentation available through "Workbench tool">About>Documentations>Documentation>"User manual" tab, "PID regulator theoretical background" and "A priori determination of flux and torque current PI gains".
PID tuning could be done directly with MC Motor Pilot by clicking on the "Advanced Configuration" button.
2025-04-16 1:50 AM
Hello @EDokm,
