2019-04-09 06:31 AM
i have problems to install the ST MC Workbench (x-cube-mcsdk_5.3.3). If i want to install the file, i get the an error:
Error Opening file for writing:
C:ßProgram Files
(x86)\STMicroelectronics\MC_SDK_5.3.3\Middlewares\ST\Motor
Control\MotorControl_Config.xml
Can anybody help me?
2019-04-15 11:13 PM
Solved!
2019-04-15 11:13 PM
Solved!
2021-06-15 01:12 AM
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
2023-08-28 04:58 AM
Hi TKlei,
can you say how did you solve it. cause i'm also facing the same error
