I can't install ST MC Workbench Software (x-cube-mcsdk_5.3.3) ?
TKlei.5
i have problems to install the ST MC Workbench (x-cube-mcsdk_5.3.3). If i want to install the file, i get the an error:
Error Opening file for writing:
C:ßProgram Files
(x86)\STMicroelectronics\MC_SDK_5.3.3\Middlewares\ST\Motor
Control\MotorControl_Config.xml
Can anybody help me?
TKlei.5
3 REPLIES 3
TKlei.5
Solved!
Laurent Ca...
Lead II
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
Hi TKlei,
can you say how did you solve it. cause i'm also facing the same error
