How to run motor in Open Loop
‎2020-10-30 5:34 AM
Hi
I am running on a STM32G071 board, with my own custom HW (standard 3 phase halfbridge). The control is FOC sensorless with 1 shunt
I am having problems tuning the motor, but for starters I would like to run the motor at low speed in open loop
I can find a parameter in the IOC file name Open_Loop_FOC which I can set to "true"
But how do I set the operating conditions and how do I start the motor in Open loop mode?
(I am running MCWB 5.4.1.19309 (I have tried 5.4.4, but it seems to be unstable. STM32CubeIDE 1.4.2 and STM32CubeMX 6.0.1)
Klaus
- Labels:
STM32 Motor Control
STM32G0 Series
‎2020-11-02 6:47 AM
I think you have this issue due to the use of an old version of the MC Workbench.
The issue is in drive_parameters.h, be sure to have these declarations:
Best Regards,
Antoine
‎2020-11-02 2:15 AM
Hello KKrag.1,
To run a motor in open loop, as you said you need to set "OPEN_LOOP_FOC" to true in the IOC file and generate the project with STM32CubeMx.
In your project, you can find:
- in drive_parameters.h: open loop parameters
- in mc_task.c, in the medium frequency task, at START state, the open loop algorithm is performed
To control your application, you can use functions in mc_api.c.
For example, to start your motor, you can call MC_StartMotor1(void).
Let me know if you need more detailed explanation.
Best Regards,
Antoine
‎2020-11-02 4:56 AM
Hi Antoine
Thanks for the answer
When I change the Open_Loop_FOC to "true", I get compile time errors:
mc_config.c:135:67: error: 'PHASE2_FINAL_SPEED_UNIT' undeclared here (not in a function); did you mean 'PHASE1_FINAL_SPEED_UNIT'?
{(uint16_t)PHASE2_DURATION,(int16_t)(PHASE2_FINAL_SPEED_UNIT),(int16_t)PHASE2_FINAL_CURRENT,&RevUpControlM1.ParamsData[2]},
mc_config.c:136:67: error: 'PHASE3_FINAL_SPEED_UNIT' undeclared here (not in a function); did you mean 'PHASE2_FINAL_SPEED_UNIT'?
{(uint16_t)PHASE3_DURATION,(int16_t)(PHASE3_FINAL_SPEED_UNIT),(int16_t)PHASE3_FINAL_CURRENT,&RevUpControlM1.ParamsData[3]},
mc_config.c:137:67: error: 'PHASE4_FINAL_SPEED_UNIT' undeclared here (not in a function); did you mean 'PHASE3_FINAL_SPEED_UNIT'?
{(uint16_t)PHASE4_DURATION,(int16_t)(PHASE4_FINAL_SPEED_UNIT),(int16_t)PHASE4_FINAL_CURRENT,&RevUpControlM1.ParamsData[4]},
Any hint to how to avoid those?
Klaus
‎2020-11-02 6:47 AM
Best Regards,
Antoine
‎2020-11-09 5:40 AM
Hello @Community member​,
Antoine’s answers finally solved your problem?
If yes please click on the 'Select as Best' button in the proper reply.
‎2022-07-14 9:45 PM
Looking for this OPEN_LOOP_FOC, but not finding it. Runing 5.y.4
‎2022-07-20 2:20 AM
you need to open the .ioc file in editor and search for OPEN_LOOP_FOC
‎2022-07-20 9:08 AM
Thank you! I did find this and have it functioning. Curious why this isn't in the gui?
