2023-05-19 12:07 AM - edited 2023-11-20 05:06 AM
similar question as https://community.st.com/s/question/0D53W00001wHk5BSAS/motor-wont-start-with-motor-pilot
I am trying to run a BLDC motor using Motor Pilot 6.1.1 with B-G431B-ESC1.
Here's my process.
when in IDLE mode, the motor is making a wierd knocking noise, at a rate of 1 sec.
and when I press start, the status change to START, the motor(or the board; I'm not sure) makes beep noise once(for about 0.5s) and the state returns to IDLE.
Please help. Thanks.
2023-05-23 12:56 AM
as it turns out my motor is broken. no need for an answer
2023-05-23 12:56 AM
