2023-02-01 8:04 AM
Hi, what does this mean?
[ERROR] - MotorControlProtocol: ASPEP_RESP ERROR:CMD_NOK
Using MotorControl V6, motor won't start.
2023-02-02 1:57 AM
hello @Popeye ,
this error means that the command you sent to the firmware does not seem to be recognized.
Can you please tell me what you did to get this error so that I can reproduce the problem and propose a solution.
Thank you
2023-02-02 3:02 AM
@Zied b. , I suspect I got this error because I was unknowingly using the Motor Pilot 6-step GUI for an FOC application. I'll update this thread if that wasn't the issue.
