2020-02-13 07:03 PM
2020-03-05 06:20 AM
That's the right version of MCSDK, Thanks!
Can you please check your IDE version as well?
2020-03-05 06:38 AM
CubeIDE is 1.3.0
2020-03-05 06:44 AM
Thanks,
Indeed we will start investigation => it does not explain the problem
2020-03-05 01:58 PM
I have been able to build and run projects in the SDK_5.4.3 directory using the Keil Tool chain (MDK-ARM) though on some I needed to optimize size not time, to keep below the 32k limit on the Lite version.
2020-10-16 12:39 AM
Dear @Jace , dear @BTrem.1
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found.
Best regards
Laurent Ca...
2020-10-16 08:41 AM
