Voice compressing in STM32L4
‎2025-01-09 12:56 AM
STM32L4 series
‎2025-01-09 1:05 AM
Stm32F1 and stm32L4 both have arm cortex M processors.
What problems do you get offering the STM32F1 assembly files to an assembler for L4?
‎2025-01-09 1:28 AM - edited ‎2025-01-09 1:29 AM
STM32F1 uses M3 core
STM32L4 uses M4 core
I do not want to put a lot effort into getting it to work if there is an obvious issue.
‎2025-01-09 7:02 AM
Opus is BSD licensed. If that works for you you can use a non-ST port/implementation of OPUS.
https://opus-codec.org/license/
https://github.com/xiph/opus
Click "Accept as Solution" if a reply solved your problem. If no solution was posted please answer with your own.
‎2025-01-13 1:39 AM
Problem with Opus is the flash size, not the license.
‎2025-01-13 11:06 AM - edited ‎2025-01-22 7:52 AM
Have you tried porting the speex library? What assembler files need to be ported? I can't find the example.
‎2025-01-15 5:25 AM
No, I wrote I donot put effort in something that already have issues.
The STM32F1 code is not at ST website, but found it here
‎2025-01-15 7:48 AM
Cortex-M4 is a superset of Cortex-M3.
‎2025-01-16 1:39 AM
@RFlod.2 wrote:No, I wrote I donot put effort in something that already have issues.
What issues? Do you get compile errors or doesn't the program operate properly?
Like @waclawek.jan wrote the M4 is a superset of the M3. So inline assembly should work.
If not use C code instead of assembly code. If that doesn't perform enough you can try to see if you can use CMSIS DSP library: https://github.com/ARM-software/CMSIS-DSP
‎2025-01-16 2:00 AM
It wil take time to implement and verify this implementation.. It would be preferable to use an existing working solution.
Debugging assembler is something I would like to avoid. Even though the core might be compatible there can be callls to other oarthe in the STM32 which are not compatible.
