Unable to pair DWM1000
Rituraj
I am trying to use DWM1000 for ranging as well as communication but I am unable to do it . I debugged the code and Know that Initiator is sending data but is not being heard . The Rx buffer in responder is geting updated by random values.
I have attached the code to both here . If anyone could help it will be very helpful.
https://drive.google.com/drive/folders/16WMlzlzvSzrWMwefvTAwKB4aY1TVz7GR?usp=sharing
https://drive.google.com/drive/folders/14RmWrQQ4oUgmkux6U1B235Gc2GPwN-bo?usp=sharing
18 REPLIES 18
SofLit
Hello @Rituraj ,
Better to attach the code with zip/rar instead of Google drive.
Thank you for your understanding.
PS:
You mean this: https://www.qorvo.com/products/p/DWM1000 ?
Did you see their Application Note APS022, "Debugging DW1000-Based Products and Systems" ?
Have you contacted Qorvo for support: https://www.qorvo.com/support/technical-support ?
How do you know that?
Is it sending valid data?
@Andrew Neil I know that it because an array is being sent and it is hardcoded , also every time transmission happend a variable is incremented . So I wrote on that basis.
I tried connecting at QORVO but did not get a response.
@SofLit will make that sure next time.
Does that guarantees that any radio transmission actually took place?
I have been working under the assumtion that it means so.  Is there a way to check if the transmission is actully taking place.
@Rituraj wrote:
 Is there a way to check if the transmission is actually taking place.
You'd have to ask Qorvo that.
Did you look at their App Note?
Yes I did have look at application notes but did not find the answer
The App Note is titled, "Debugging DW1000-Based Products and Systems".
I wouldn't expect that to provide the answer - just tell you how to find problems ...
