STM32H723ZG - no target detected
Mylossh
Hello everyone, I've designed a custom board with STM32H723ZG, previously based on STM32F767ZG. When I connect board with ST Link V2 prog through SWDIO, SWDCLK and GND, I get response that no target has been detected. I'm currently using ST-Link Utility software. If I desolder H723ZG and replace it with F767ZG, board works completely fine, without any issues.
What could possibly be issue, should I order ST-Link V3 prog for the H723 MCU?
Please check attached schematic of the board, MCU related stuff is on second page.
Thanks everyone in advance! :)
SofLit
ST-Link Utility software is obsolete. Start using STM32CubeProgrammer tool.
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
4 REPLIES 4
SofLit
MNapi
Senior III
how did you solder this chip?
are you sure all power pins are connected (soldered properly) including PA13, PA14 for debugging ?
Mylossh
Looks like recommendation from @SofLit solved the issue! :)
Thanks a lot!!
That's good - please mark the solution.
