st-link driver installation for Windows 11
greenthumb
Hello, I am having trouble connecting my nucleo board to my pc because the port is not being recognized. I downloaded the st-link 009 usb driver without any problems but when i connect the board the com port and the device doesnt show up. In the description it says its compatible up to Windows 10 but I read on other forums that people with windows 11 did get theirs to work. I'm not getting errors its just not showing up. What am I missing?
SofLit
Did you try the same config with another machine (USB cable+STLink probe) with Windows 10?
Are you sure your cable is a data cable and not a charging cable?
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
6 REPLIES 6
SofLit
PS:
Thank you, I was indeed using a charging cable and not a data cable!
Angel12345
I am facing same issue, So i am trying to install st-link-009 driver, this also not getting installed, ports are not recognized in windows 10
Hello @Angel12345 and welcome to the community,
This is not the same issue. So, please open a new thread as this was closed and describe your exact steps to reproduce the behavior.
Thank you for your understanding.
PS:
Angel12345
ok, I am new here, dont know how to open, if you know solution, let me know, what could be done
Click on that button on the home page of the community.
Also review tips in this link on how to post a thread.
PS:
