st-link driver installation for Windows 11
greenthumb
Hello, I am having trouble connecting my nucleo board to my pc because the port is not being recognized. I downloaded the st-link 009 usb driver without any problems but when i connect the board the com port and the device doesnt show up. In the description it says its compatible up to Windows 10 but I read on other forums that people with windows 11 did get theirs to work. I'm not getting errors its just not showing up. What am I missing?
SofLit
Did you try the same config with another machine (USB cable+STLink probe) with Windows 10?
Are you sure your cable is a data cable and not a charging cable?
SofLit
Thank you, I was indeed using a charging cable and not a data cable!
