SDMMC + FATFS on STM32H753Zx
Naresh_
   i go to start SDMMC1 in STM32H753z, is any sample code? can please provide.
   in SDMMC i need to use FATFS APIs or SDMMC APIs ? i am confusing please help me.
   when i debug the below code i am can n't access it stop at f_mount() starting only.
please provide how to use SDMMC.
Thank You
Hi Tesla,
        thank you for fast response,
i have using STM32H753Z custom board, my requirement is read and write in SDMMC (SD card) ,
i am using SDMMC1    PC8 -> SDMMC1_D0
                                     PC9-> SDMMC1_D1
                                     PC10-> SDMMC1_D2
                                      PC11-> SDMMC1_D3
                                      PC12-> SDMMC1_CLK
                                       PD2-> SDMMC1_CMD
                                   PB1 -> CARD_DETECT(GPIO_INPUT)
                                  PB2 -> WR_PROTECT(GPIO_INPUT)
 my issue is when i debug then disk_initialize(pdrv)  pdrv is 0  return the 1 means it not dictated SD card.
before that i am reading  PB1 -> CARD_DETECT (GPIO_INPUT) by using HAL_GPIO_ReadPin(GPIOB, GPIO_PIN_1)  when card is placed then it return "0".
6 REPLIES 6
STM32Cube_FW_H7_V1.10.0\Projects\STM32H743I-EVAL\Applications\FatFs\FatFs_uSD_Standalone
Hi Tesla,
                                     PC9-> SDMMC1_D1
                                     PC10-> SDMMC1_D2
                                      PC11-> SDMMC1_D3
                                      PC12-> SDMMC1_CLK
                                       PD2-> SDMMC1_CMD
You need to adapt the example pointed out by @Tesla DeLorean to your custom HW
hi
i have using adapter (DM1AA-SF-PEJ-82) part number
Even with this adapter you can adapt the example with your HW. So you need to check this Card Connector pinout.
You need to refer to DM1AA-SF-PEJ-82 documentation.
hi Soflit,
       actually Hardware connection is okey but in stm32h7xx_hal_sd.c file
when i power ON by using this function is SD_PowerON(SD_HandleTypeDef *hsd)  some API is providing time out as below in this are1)  SDMMC_CmdOperCond(hsd->Instance);
                          2)SDMMC_CmdAppCommand(hsd->Instance, 0)
most of  time getting  flag  is 4(time out )  and  some time 1 ( CRC mismatch).
