2019-07-16 9:25 AM
Hey everybody,
I just got it working that I can use my SD Card as an USB MSD. I can write, read and delete files. Everything looks good.
The only problem is that when I connect the USB cable to my computer it takes like 2-3 minutes until the SD card is visible in the explorer. Furthermore, Windows popup window tells me that there is a problem with the mass storage device. However, everything works fine after that. There is not really a problem.
The only problem is that it takes so long until Windows displays the SD card.
Does anybody have an idea why?
I would really appreciate your help!
2019-09-12 10:47 PM
could you guide me , how you have implement usb msd on your device
i am using stm32f779bi for my project
thanks in advance
