Problem with I2C in DMA mode in the latest versions of the F4 STM32Cube FW
STomm.1
Hello everyone.
I think that the stm32f4xx_hal_i2c.c driver present in the STM32Cube_FW_F4_V1.25.1 and STM32Cube_FW_F4_V1.25.2 versions has a bug on I2C transfer in DMA mode.
In the function:
"I2C_MemoryTransmit_TXE_BTF" the value of "hi2c->MemaddSize" remains 0 even when the I2C internal memory address size is 8 bit (I2C_MEMADD_SIZE_8BIT).
This causes the malfunction of the function "HAL_I2C_Mem_Write_DMA"
As a workaround I added the following setting in the MX_I2C1_Init function
hi2c1.MemaddSize = I2C_MEMADD_SIZE_8BIT;
Has anyone else experienced this problem before and how did they solve it?
Amira
Apologies for the delayed response. The reported issue is confirmed.
 hi2c->MemaddSize = MemAddSize; initialization is added now in HAL_I2C_Mem_Read_DMA() and HAL_I2C_Mem_Write_DMA() APIs for  /* Prepare transfer parameters *.
The fix will be available in next STM32F4 patch release V1.26.2.
Amira
6 REPLIES 6
Guru
Agreed. Seems like this value should be set within HAL_I2C_Mem_Write_DMA since the IRQHandler needs to know it.
Amel NASRI
Hi @STomm.1​ ,
Thanks for bringing this issue to our attention. With my quick analysis, I assume that it was introduced since the revision 1.25.0 of STM32CubeF4 package as the function I2C_MemoryTransmit_TXE_BTF was added with it.
I reported it to our development team who should do a deeper analysis and provide a solution.
Meanwhile, could you please explain more the "malfunction of HAL_I2C_Mem_Write_DMA"? Does it mean that there is no data transferred?
-Amel
STomm.1
Hi Amel.
I haven't done a thorough analysis; I use DMA mode to program, read/write 3 IO_Expander. What I noticed is this:
1) the first time the HAL_I2C_Mem_Write_DMA function is called (to program the IO_expander), the I2C_MemoryTransmit_TXE_BTF function is called 2 times consecutively; the first time it sees hi2c-> MemaddSize = 0 and then sets hi2c-> Instance->DR = I2C_MEM_ADD_MSB. I believe this causes error in the programming of the IO_Expander.
2) Putting hi2c1.MemaddSize = I2C_MEMADD_SIZE_8BIT in the MX_I2C1_Init, the function I2C_MemoryTransmit_TXE_BTF is always called 2 times consecutively, but this time it sets (I think correctly) hi2c->hi2c->Instance->DR = I2C_MEM_ADD_LSB.
3) In the subsequent calls of the HAL_I2C_Mem_Write_DMA function the I2C_MemoryTransmit_TXE_BTF function it is instead called (I think correctly) once.
So I'm wondering if the initial double call of the I2C_MemoryTransmit_TXE_BTF function may be the problem.
Tommaso
Hi @STomm.1​ ,
Thanks for your answer.
Is it possible for you to share with us a minimum code that can help to reproduce the issue?
-Amel
STomm.1
Hi Amel, it's quite simple: the problem occurs on the first call of the HAL_I2C_Mem_Write_DMA function, in mcp23017_init.
main.c:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * <h2><center>&copy; Copyright (c) 2019 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under Ultimate Liberty license
  * SLA0044, the "License"; You may not use this file except in compliance with
  * the License. You may obtain a copy of the License at:
  *                             www.st.com/SLA0044
/* USER CODE END Header */
#include "main.h"
#include "adc.h"
#include "can.h"
#include "dma.h"
#include "i2c.h"
#include "rtc.h"
#include "tim.h"
#include "usart.h"
#include "usb_device.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
#include "platform/port.h"
#if (IO_EXP_PRESENT==1)					//Defined in main.h
	#include "platform/mcp23017.h"
#endif
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* USER CODE BEGIN PV */
uint8_t mystring[]="Test String !!!\r";
uint8_t send_data_uart=32, receive_data_uart=0, echo_receive_data_uart=0;
FLASH_DATA_ORG FlashDataOrg = {.b_date_offset = 0x00, .b_time_offset = 0x04,
.b_mdata.DeviceName_offset = 0x08, .b_mdata.HW_Version_offset = 0x0C, .b_mdata.SW_Version_offset = 0x10,
.b_mdata.Vendor_ID_offset = 0x14, .b_mdata.Prdct_Code_offset = 0x18, .b_mdata.Rev_Number_offset = 0x1C, .b_mdata.Ser_Number_offset = 0x20,
.b_status.s0_offset = 0x24, .b_status.s1_offset = 0x28, .b_status.s2_offset = 0x2C, .b_status.s3_offset = 0x30,
.b_status.s4_offset = 0x34, .b_status.s5_offset = 0x38, .b_status.s6_offset = 0x3C, .b_status.s7_offset = 0x40,
.b_status.s8_offset = 0x44, .b_status.s9_offset = 0x48, .b_status.sa_offset = 0x4C, .b_status.sb_offset = 0x50,
.b_status.sc_offset = 0x54, .b_status.sd_offset = 0x58, .b_status.se_offset = 0x5C, .b_status.sf_offset = 0x60};
/* USER CODE END PV */
/* USER CODE BEGIN PFP */
extern void my_app(void);
app_t 	app;
can_t 	can1app, can2app;
//extern void initialise_monitor_handles(void);	//Only for semi-hosting openOCD debug
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
//  initialise_monitor_handles();		//Only for semi-hosting openOCD debug
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_ADC1_Init();
  MX_I2C1_Init();
  MX_RTC_Init();
  MX_TIM2_Init();
  MX_TIM3_Init();
  MX_USB_DEVICE_Init();
  MX_CAN1_Init();
  MX_CAN2_Init();
  MX_TIM1_Init();
  MX_TIM12_Init();
  MX_USART3_UART_Init();
  MX_TIM6_Init();
  MX_TIM7_Init();
  /* USER CODE BEGIN 2 */
//  HAL_NVIC_DisableIRQ(ADC1_2_IRQn);
  HAL_NVIC_ClearPendingIRQ(ADC_IRQn);
  HAL_NVIC_ClearPendingIRQ(EXTI0_IRQn);
  HAL_NVIC_ClearPendingIRQ(EXTI1_IRQn);
  HAL_NVIC_ClearPendingIRQ(EXTI2_IRQn);
  HAL_NVIC_ClearPendingIRQ(EXTI3_IRQn);
  HAL_NVIC_ClearPendingIRQ(EXTI4_IRQn);
  HAL_NVIC_ClearPendingIRQ(TIM6_DAC_IRQn);
  HAL_NVIC_ClearPendingIRQ(I2C1_EV_IRQn);
  HAL_NVIC_DisableIRQ(TIM6_DAC_IRQn);
  HAL_TIM_Base_Stop_IT(&htim6);				// Stop Timer 6
  HAL_TIM_Base_Start(&htim1);
  HAL_TIM_Base_Start(&htim2);
  HAL_TIM_Base_Start_IT(&htim3);			// Start Timer 3
  HAL_TIM_Base_Start_IT(&htim7);			// Start Timer 7
  ServiceTimersInit();						// Initialize all Service Timers
#if (CAN_SUPPORT==1)						// Defined in port.h
  CAN_Config(&hcan1);						// Configure the CAN peripherals
  CAN_Config(&hcan2);
#endif
#if (USART_SUPPORT==1)						//Defined in port.h
//  USART_Config(&huart2);
//  __HAL_UART_ENABLE_IT(&huart2,UART_IT_RXNE);
  USART_Config(&huart3);;
  __HAL_UART_ENABLE_IT(&huart3,UART_IT_RXNE);
#endif
  ADC_Config(&hadc1);						// Configure the ADC peripheral
  Sleep(1);
#if (IO_EXP_PRESENT==1)						// Defined in main.h
  MCP23017_status = MX_MCP23017_Init();
#endif
  leds_test = true;							// Blink LEDs if init Ok
  /* Start main application */
  my_app();
  /* USER CODE END 2 */
MX_MCP23017_Init:
 *  \fn			MX_MCP23017_Init()
 *  \brief      Initialize the MCP23017 IO Expanders
MCP23017_Error_et MX_MCP23017_Init()
	if (mcp23017_init(master_1, MCP23017_MASTER1_BADDR))
		return MCP23017_ERROR;
	HAL_Delay(i2c_delay);
	if (mcp23017_init(master_2, MCP23017_MASTER2_BADDR))
#if (USE_PWRGEN==1)
	if (mcp23017_init(master_3, MCP23017_MASTER3_BADDR))
#endif
	return MCP23017_OK;
uint8_t master_1[22] = {
							MASTER1_IODIRA,
							MASTER1_IODIRB,
							MASTER1_IPOLA,
							MASTER1_IPOLB,
							MASTER1_GPINTENA,
							MASTER1_GPINTENB,
							MASTER1_DEFVALA,
							MASTER1_DEFVALB,
							MASTER1_INTCONA,
							MASTER1_INTCONB,
							MASTER1_IOCONA,
							MASTER1_IOCONB,
							MASTER1_GPPUA,
							MASTER1_GPPUB,
							MASTER1_INTFA,
							MASTER1_INTFB,
							MASTER1_INTCAPA,
							MASTER1_INTCAPB,
							MASTER1_GPIOA,
							MASTER1_GPIOB,
							MASTER1_OLATA,
							MASTER1_OLATB
uint8_t master_2[22] = {
							MASTER2_IODIRA,
							MASTER2_IODIRB,
							MASTER2_IPOLA,
							MASTER2_IPOLB,
							MASTER2_GPINTENA,
							MASTER2_GPINTENB,
							MASTER2_DEFVALA,
							MASTER2_DEFVALB,
							MASTER2_INTCONA,
							MASTER2_INTCONB,
							MASTER2_IOCONA,
							MASTER2_IOCONB,
							MASTER2_GPPUA,
							MASTER2_GPPUB,
							MASTER2_INTFA,
							MASTER2_INTFB,
							MASTER2_INTCAPA,
							MASTER2_INTCAPB,
							MASTER2_GPIOA,
							MASTER2_GPIOB,
							MASTER2_OLATA,
							MASTER2_OLATB
#if (USE_PWRGEN==1)
uint8_t master_3[22] = {
							MASTER3_IODIRA,
							MASTER3_IODIRB,
							MASTER3_IPOLA,
							MASTER3_IPOLB,
							MASTER3_GPINTENA,
							MASTER3_GPINTENB,
							MASTER3_DEFVALA,
							MASTER3_DEFVALB,
							MASTER3_INTCONA,
							MASTER3_INTCONB,
							MASTER3_IOCONA,
							MASTER3_IOCONB,
							MASTER3_GPPUA,
							MASTER3_GPPUB,
							MASTER3_INTFA,
							MASTER3_INTFB,
							MASTER3_INTCAPA,
							MASTER3_INTCAPB,
							MASTER3_GPIOA,
							MASTER3_GPIOB,
							MASTER3_OLATA,
							MASTER3_OLATB
#endif
 *  \fn         MCP23017_Error_et mcp23017_init(uint8_t *RegValues, uint8_t address)
 *  \brief      Initialize the MCP23017 device.
MCP23017_Error_et mcp23017_init(uint8_t *RegValues, uint8_t base_address)
	if (HAL_I2C_Mem_Write_DMA(&hi2c1,(uint16_t)base_address,0,I2C_MEMADD_SIZE_8BIT,(uint8_t*)RegValues,22))
	return MCP23017_OK;
Tommaso
Amira
Amira
