2021-02-06 04:19 AM
Hi!
SD_ write function in sd_diskio_dma_rtos_template_bspv1.c in STM32Cube_FW_F7_V1.16.0 contains some strange bug. The first part of this function, where we do not need to use of scratch buffer, it waits for correct message WRITE_CPLT_MSG, but in the second part where it uses scratch buffer, it waits for READ_CPLT_MSG. This seems wrong.
Thank you!
Update: Still there even in new 1.16.1 version.
2021-02-08 11:49 PM
Hello @Zed ,
I will review your issue and I will come back to you as soon as possible to inform you about the taken actions/explanation if needed.
Thanks for your contribution.
Imen
2021-07-31 03:03 PM
Hi @Zed ,
Sorry for the delayed answer.
Our team are working to fix the issue and it will be published in next release.
So, keep an eye out for the coming update.
Thank you for your patience while we work on this.
Imen
