2018-10-08 05:54 AM
2018-10-08 06:17 AM
What do you mean, "directly" ?
If you use Ethernet, you will still need the usual Ethernet magnetics, PHY, etc.
When you say, "increase the data rated speed" - relative to what?
2018-10-08 06:44 AM
I was assigned the task "Connect the WiFi-module to the STM32 via the Ethernet interface". I want to know if this will work correctly?
Regarding the data transfer rate, I meant that Ethernet allows you to have high speed relative to other interfaces.
