How to stop listening port on tcp communication properly with LWIP Stack ?
‎2022-10-27 6:20 AM
Hello, I have a mcu that works as a tcp server. I listen 2 port for connection, if i want to stop listening what must i do ?
I use this function to initialise port
void TCPServerInitialise( U16 usPort )
struct tcp_pcb *pstTcp_pcb;
/* create new tcp pcb */
pstTcp_pcb = tcp_new (); // allocate new tcp_pcb
if ( pstTcp_pcb != NULL )
err_t err;
/* bind pcb to port */
err = tcp_bind ( pstTcp_pcb, IP_ADDR_ANY, usPort );
CONSOLE_PRINT_1( "Tcp_Bind Err : %d", err );
if ( err == ERR_OK )
/* start tcp listening for pcb */
pstTcp_pcb = tcp_listen( pstTcp_pcb );
if ( usPort == stPRM.stTransParams.st485Cfg.usETHPort )
mLedEth485StatusSet()
stTaskETH.pst_tcp_pcb_485 = pstTcp_pcb;
else if ( usPort == stPRM.stTransParams.st232Cfg.usETHPort )
mLedEth232StatusSet()
stTaskETH.pst_tcp_pcb_232 = pstTcp_pcb;
/* initialize LwIP tcp_accept callback function */
tcp_accept ( pstTcp_pcb, TCPServerAcceptCallback );
CONSOLE_PRINT_1( "Port %d is up !", usPort );
else
EventInsert( eEventTcpInitFail );
/* deallocate the pcb */
memp_free ( MEMP_TCP_PCB, pstTcp_pcb );
I tried tcp_close ( stTaskETH.pst_tcp_pcb_232 ); and tcp_close ( stTaskETH.pst_tcp_pcb_232 ); but still i have issues tcp_close didnt clear variables.
- Labels:
Ethernet
‎2022-10-27 1:28 PM
What about "tcp_close( pstTcp_pcb )" (i.e. close the instance that you are "listening" with? When you close the pcb that you get from the "accept" call, the "listen" pcb is still active.
‎2022-10-27 3:37 PM
A very important question - does the project use RTOS? Also take a note that tcp_close() is not guaranteed to succeed.
By the way else if in the line 28 doesn't make sense. Take the if part away or introduce the third option with just an else.
‎2022-10-30 10:31 PM
No, Project does not use RTOS.
I use tcpcloseCallback function like below.
void TCPServerConnectCloseCallback( struct tcp_pcb *pstTpcb, struct echoserver *pstEs )
if( pstTpcb == stTaskETH.pstEs485->pcb )
stTaskETH.pstEs485 = NULL; // must be here
mLedEth485StatusClear();
else if( pstTpcb == stTaskETH.pstEs232->pcb )
stTaskETH.pstEs232 = NULL; // must be here
mLedEth232StatusClear();
/* remove all callbacks */
tcp_arg(pstTpcb, NULL);
tcp_sent(pstTpcb, NULL);
tcp_recv(pstTpcb, NULL);
tcp_err(pstTpcb, NULL);
tcp_poll(pstTpcb, NULL, 0);
/* delete pstEs structure */
if (pstEs != NULL)
mem_free(pstEs);
/* close tcp connection */
tcp_close(pstTpcb);
This function always close connection successfully from client side but i cannot close port listening. I hope i could explain clearly
