[Bug] Undefined behavior in LL_ADC_SetChannelSingleDiff causes it to alway set bits in gcc and clang
Morty Morty
From LL_ADC_SetChannelSingleDiff:
 /* Bits of channels in single or differential mode are set only for        */
 /* differential mode (for single mode, mask of bits allowed to be set is   */
 /* shifted out of range of bits of channels in single or differential mode. */
The assumption that it is ok to shift the bits out of the register is wrong, because it is undefined bahviour: C11 6.5.7 / http://c0x.coding-guidelines.com/6.5.7.html
This causes gcc (https://godbolt.org/z/eH-T_m), as well as clang (and therefore probably armcc, too), to replace the bic-instruction with an orr-instruction; inverting the intent.
The reasoning why they do that can be found here:
https://gcc.gnu.org/ml/gcc/2019-03/msg00077.html
Imen.D
Hello Morty,
Thanks for reports this issue.
We will look on this issue, then we will keep you updated.
Kind Regards,
Imen
Imen
Imen.D
Hello @Moritz Strübe​ ,
This issue will be fixed on the coming release of all relevant STM32 series.
Thank you for your contribution.
Best Regards,
Imen
Imen
