ADC_DMA_Transfer example on NUCLEO-U575ZI-Q board failure to go through
‎2023-10-31 09:24 AM
I am loading and running example "ADC_DMA_Transfer" on NUCLEO-U575ZI-Q board but failed go through on function call
MX_ADC4_Init();
Step into this function, the software trapped in the ADC calibration process.
if (HAL_ADCEx_Calibration_Start(&hadc4, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED) != HAL_OK)
Error_Handler();
The software failed to start calibration and then tangled in Error_Handler() permanently.
I searched through the early post but didn't find right solution.
Any thought on this issue? Thanks.
STM32U5 series
‎2023-10-31 12:18 PM
Hi, I found the issue, it is related to my hardware board. After I fixed the hardware (on power section) the ADC is working fine.
Appreciate your help.
‎2023-10-31 11:16 AM - edited ‎2023-10-31 11:16 AM
Hello @hguan
Could you check which kind of errors do you get from HAL? Is it linked to configuration/DMA error?
Could you share more details to reproduce the error?
Dump errors from registers view as well to make sure they are linked properly.
‎2023-10-31 11:53 AM
Thank you for your quick response.
The dead loop happened during function call of HAL_ADCEx_Calibration_Start(...) within
stm32u5xx_hal_adc_ex.c.
Inside the HAL_ADCEx_Calibration_Start(...), it calls LL_ADC_IsCalibrationOnGoing(...)
/* Wait for calibration completion */
while (LL_ADC_IsCalibrationOnGoing(hadc->Instance) != 0UL)
wait_loop_index++;
if (wait_loop_index >= ADC_CALIBRATION_TIMEOUT)
/* Update ADC state machine to error */
ADC_STATE_CLR_SET(hadc->State, HAL_ADC_STATE_BUSY_INTERNAL, HAL_ADC_STATE_ERROR_INTERNAL);
__HAL_UNLOCK(hadc);
return HAL_ERROR;
The function LL_ADC_IsCalibrationOnGoing(...) always return non-zero value:
READ_BIT(ADCx->CR, ADC_CR_ADCAL) = 0x80000000
Once the timeout reaches ADC_CALIBRATION_TIMEOUT, it returns HAL_ERROR to the caller and then the software hungs up in the
Error_Handler().
The hardware board in my test is using STM32U575VIT6Q, not the evaluation board NUCLEO-U575ZI-Q.
