X_Cube_AI person detection program display error
Prathish
Sir, when I flashed the stm32 board with a Ai model of person detection code, with our custom model, the display was showing like this (glitches), what should I do now?
Do I need to do any boot up program for the display?
1 REPLY 1
liaifat85
Senior III
You did not mention exactly which display you're using. By the way, this doc may help in general regarding presence sensing by STM boards.
https://www.st.com/en/applications/sensing/presence-sensing.html#overview
I will look for more contents for your assistance. By the way, if you wish to make an IoT STM32 Build IoT Application From Scratch, you can see here.
https://www.pcbway.com/project/shareproject/STM32_Build_IoT_Application_From_Scratch_With_RYWB116_WiFi_Module_ce613b0c.html
