2018-12-10 02:30 AM
discussed in earlier threads, STLINKV3 does not appear on USB3 ports on Linux. It does appear on the same physical machine when run on a virtual machine with Virtualbox. Has this problem been realized by the developpers? Is there any solution to expect in a sensible time frame?
2019-01-01 01:18 PM
Short answer: I’m using it under Debian 9.6.
Longer answer:
and enjoy. You’ll find the gory details at https://mbd.kleier.net/integrating-st-link-v3.html.
2019-01-02 04:26 AM
Okay, my question was not clear. I meant "appear" in STM32CubeProg!
2019-01-02 06:45 AM
Okay. I just wanted to bolster you up. ☺ Because it is kind of working just now, it can be expected to be integrated into higher environments soon. But, to be honest, there is way to go to reach a comfortable environment. And we require a small shield to connect a power supply and the external ST-Link/V3.
