STM32F746 cannot read level of audio input signal
aciuf
I would like to read the level of audio input signal to use like a vu-meter instead of use analog input.
This is my code but I read always 0dB on both channels.
void AUDIO_PLAYER_Init2()
/* Allocat mem for Smr */
pSmrPersistentMem = malloc(smr_persistent_mem_size); /* smr_persistent_mem_size 0x188 */
pSmrScratchMem = malloc(smr_scratch_mem_size); /* smr_scratch_mem_size 0xF04 */
if (BSP_AUDIO_IN_Init(INPUT_DEVICE_INPUT_LINE_1, 80, AUDIO_FREQUENCY_48K) != 0)
LCD_LOG_SetHeader((uint8_t *)"Audio SMR Application KO");
else
LCD_LOG_SetHeader((uint8_t *)"Audio SMR Application OK");
void Audio_Process2()
    int32_t error = SMR_ERROR_NONE;
    __HAL_RCC_CRC_CLK_ENABLE();
    CRC->CR = CRC_CR_RESET;
    error = smr_reset(pSmrPersistentMem, pSmrScratchMem);
    if (error != SMR_ERROR_NONE)
        BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--err0--", LEFT_MODE);
        return (AUDIO_ERROR_SMR);
    smr_static_param.sampling_rate = 48000; /* only sampling rate supported */
    error = smr_setParam(&smr_static_param, pSmrPersistentMem);
       BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--err1--", LEFT_MODE);
    smr_dynamic_param.enable = 1; /* SMR module enabler */
    smr_dynamic_param.averaging_time = AUDIO_CFG_SMR_AVGTIME_DEFAULT;
    smr_dynamic_param.filter_type = SMR_PREFILTER_AWEIGHTING;
    error = smr_setConfig(&smr_dynamic_param, pSmrPersistentMem);
        BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--err2--", LEFT_MODE);
    error = smr_getConfig(&smr_dynamic_param, pSmrPersistentMem);
       BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--err4--", LEFT_MODE);
       return AUDIO_ERROR_SMR;
   BufferHandler.nb_bytes_per_Sample = 2; /* 16-bit */
   BufferHandler.nb_channels = 2; /* stereo */
   BufferHandler.data_ptr = PCM_Data_SMR;
   BufferHandler.buffer_size = 32/2; /* just half buffer is process (size per channel) */
   BufferHandler.mode = INTERLEAVED;
   BufferHandler.data_ptr = &BufferCtl.buff[AUDIO_OUT_BUFFER_SIZE /2];
   error = smr_process(pBufferHandler, pBufferHandler, pSmrPersistentMem);
     BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--err5--", LEFT_MODE);
      BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--err6--", LEFT_MODE);
sprintf((char *)str_pwr, "Left mean power: %ld dB",(int32_t)((float)smr_dynamic_param.mean_level_left*0.25));
BSP_LCD_DisplayStringAt(CHAR(0), LINE(10), (uint8_t *)str_pwr, LEFT_MODE);
sprintf((char *)str_pwr, "Right mean power: %ld dB",(int32_t)((float)smr_dynamic_param.mean_level_right*0.25));
BSP_LCD_DisplayStringAt(CHAR(0), LINE(11), (uint8_t *)str_pwr, LEFT_MODE);
14 REPLIES 14
KnarfB
Principal III
doesn't match the implentation in
32f746gdiscovery-bsp/stm32746g_discovery_audio.c at 64c20f758a907cd873e368502cf16e498934d0ec · STMicroelectronics/32f746gdiscovery-bsp (github.com)
hth
KnarfB
Andrew Neil
Evangelist III
What "audio input signal"? On what board?
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
Have you checked that there is actually any signal present at all?
Is the signal sufficient to read above 0 dB ?
@aciuf wrote:
This is my code
So what testing / investigation / debugging have you done on your code to find what's wrong with it?
I am using a STM32F746-DISCO so INPUT_DEVICE_INPUT_LINE_1 should be the line input.
Now I see some values but still not good
	if (BSP_AUDIO_IN_Init(INPUT_DEVICE_INPUT_LINE_1, 100, AUDIO_FREQUENCY_48K) != 0)
	//if (BSP_AUDIO_IN_Init(INPUT_DEVICE_DIGITAL_MICROPHONE_2, 80, AUDIO_FREQUENCY_48K) != 0)
	else
	 	BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--smr_reset--", LEFT_MODE);
	   BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--smr_setParam--", LEFT_MODE);
	/* SMR dynamic parameters that can be updated here every frame if required */
		BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--smr_setConfig--", LEFT_MODE);
	/* I/O buffers settings */
	uint16_t pbuf[100];
	    BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--smr_process--", LEFT_MODE);
    	BSP_LCD_DisplayStringAt(10, 20, (uint8_t *)"--smr_getConfig--", LEFT_MODE);
So what did you change?
@aciuf wrote:
 but still not good
In what way, "not good"?  Give numbers!
Again, are you sure that the input signal you're providing is adequate?
and are you actually feeding it a good, line-level signal?
aciuf
Using this last code the dB print without input signal start from 0dB and decrease
https://youtu.be/PohM2AMRxFI
aciuf
In the main I call at the begin
AUDIO_PLAYER_Init2
and in a loop
Audio_Process2
I have insert only 2 fuctions in the loop
aciuf
New version
Now I see some correlation from input signal and dB print but still not correct
void *pSmrPersistentMem = NULL;
void *pSmrScratchMem = NULL;
static  smr_static_param_t smr_static_param;
static  smr_dynamic_param_t smr_dynamic_param;
static  buffer_t BufferHandler;
static  buffer_t *pBufferHandler = &BufferHandler;
static  uint8_t str_pwr[100];
uint16_t PCM_Data_SMR[32]; 		/* PCM data buffer */
	else
	smr_static_param.sampling_rate = AUDIO_FREQUENCY_48K;   /* only sampling rate supported */
	smr_dynamic_param.averaging_time = 100; //AUDIO_CFG_SMR_AVGTIME_DEFAULT;
	//BufferHandler.data_ptr = PCM_Data_SMR;
	BSP_AUDIO_IN_Record(&BufferCtl.buff[0], 32/2);
	BufferHandler.data_ptr = &BufferCtl.buff[0];
    BSP_LCD_DisplayStringAt(10, 100, (uint8_t *)str_pwr, LEFT_MODE);
    BSP_LCD_DisplayStringAt(10, 120, (uint8_t *)str_pwr, LEFT_MODE);
