stlink v3 work with stm32f411 mcus
2022-03-06 10:21 AM
Hi there.ive recently made my own circuit board which and I having trouble getting the stlink v3 to detect my f411 mcu. I've checked my oscilloscope and I can see the swd, swclk , and reset lines being driven by the programmer but I'm unable to get the cubeide to detect my mcu. The power rail is also clean too.
Is there a compatibility chart for the stlink v3 somewhere please? I'm using the mini version.
- Labels:
ST-Link
STM32F4 Series
2022-03-06 11:21 AM
Yes, ST-LINK/V3 will work with any of the STM32, you might have to drop the connection rate as the V3 can clock faster than CM0(+)
For F411, make sure VCAP capacitors and voltages are correct. The VDDA is powered, as this deals with the POR and PLL too, not just ADC/DAC
Check state of NRST
Check part orientation
Test with STM32 Cube Programmer, first
2022-03-06 11:23 AM
Cheers for the confirmation! I'll have a look. I have taken a capture of the SWD lines here.
2022-03-06 11:26 AM
I've lowered the speeds. For some reason, there's an ACK failure after the turnaround. I'll have a look at your suggestions. Thanks
2022-03-06 11:29 AM
All of the required caps and voltages are connect too
2022-03-06 11:42 AM
Is it required that I connect VBAT to VDD?
2022-03-06 11:59 AM
What voltage do you measure at VCAP1 ?
VREF+ should be connected to VDDA
Data Sheet:
If VREF+ pin is present, it must respect the following condition: VDDA-VREF+ < 1.2 V
2022-03-06 1:51 PM
Thank you! The problem was with the vref pin not being connected!!!
2022-03-06 2:15 PM
Not required, but recommended.
Also see STM32F4 design guide here:
2022-03-07 9:31 AM
Could somebody please explain why vref needs connecting (or needs respecting VDDA-VREF+ < 1.2 V) in order for my MCU to work? From what I can gather, vref is only for the ADC component.
