ST-LINK V2 DEBUGGER- ERROR IN INITIALIZING WHILE FLASHING
‎2021-04-28 7:34 AM
Am trying to flash the program in STM32CubeIde Using ST-link V2 Debugger, but am getting the error "Error initializing the St-Link debugger" and "Target Not Found". Kindly help me to solve this issue. I have tried through programmer also but no effect.
shivashankari
‎2021-05-11 8:19 AM
Hello @ShivaRagu​ ,
Do you have still this problem to solve?
Which device are you using ?
Have you checked the USB cable or tried another USB port? Have you tried STM32CubeProgrammer ?
Imen
Imen
‎2021-05-11 8:19 AM
Hello @ShivaRagu​ ,
Imen
Imen
‎2021-05-11 9:28 PM
Yes, the problem got solved. thanks a lot :)
shankari
‎2021-05-12 6:08 AM
Hi @ShivaRagu​ ,
Glad to know you fixed this problem. =)
I invite you to share your solution.
Then, please mark the answer as best by clicking on the "Select as Best" button. This will help other users find this solution more quickly.
Imen
Imen
