St Link v2 connection
‎2025-04-28 11:40 AM - last edited on ‎2025-05-15 9:28 AM by Amel NASRI
I´ve bought a new ST-Link V2 from a reputable electronics Vendor (Reichelt, Germany) to connect to my Cartographer 3d scanner for a 3d Printer with an stm STM32 chip. It is connected correctly as far as I know. I cannot establish any connection. I've also tried another board that didn't get recognized, so I think my ST-Link is broken, or am I overlooking something here? They both sometimes show as SN: 31FF710631315436290343, but as soon as I try to connect they just vanish. Is the ST-Link broken, or am I missing something since this is my first time doing this?
- Labels:
ST-Link
‎2025-04-28 12:45 PM
Pin 1 of the ST-LINK 20-pin header needs to be 3.3V or the Voltage of the Target, it's an input to the ST-LINK to power the interface to your board.
You really shouldn't be powering the board from the ST-LINK (Pin 19?)
You need a common ground, but the 3V3 from the board should be going to Pin 1 of the ST-LINK
Other connections SWDIO, SWCLK, NRESET
‎2025-04-28 11:59 AM
Try another USB cable and/or another USB port. Are either boards powered up while you're trying to connect the ST-Link? Are you using STM32CubeProgrammer? Are there no error messages of some sort?
Show the a diagram on how you've connected the ST-Link to the 3D scanner board and it's pinouts.
TimerCallback tutorial! | UART and DMA Idle tutorial!
‎2025-04-29 1:29 AM
https://community.st.com/t5/stm32-mcus/how-to-solve-debugger-connection-issues/ta-p/49693
@Banabender wrote:but as soon as I try to connect they just vanish.
Vanish from where - Device Manager? Your (unnamed) programming tool?
‎2025-04-30 4:38 AM
I have tried all my USB ports in my Laptop, used a different Laptop, and tried 3 known working cables, both boards are powered while attempting to connect. I have now found a mistake in my wiring and have changed that. I don't have a pinout of the scanner unfortunately but I have connected like the manufacturer wants me to connect.
ST-Link Scanner
SWDIO SWD
SWCLK SCL
VAPP 5V and my power supply
GND GND and power supply ground
I am using STM32CubeProgrammer and I get this from the log
13:21:54 : Start STLinkUpgrade...
13:22:23 : UR connection mode is defined with the HWrst reset mode
13:22:28 : ST-LINK error (DEV_USB_COMM_ERR)
13:22:28 : Error: Problem occurred while trying to connect
as well as a popup, but I can see the ST-Link in the Task Manager the whole time.
‎2025-04-30 10:52 AM
Thanks, that was the issue as well as I didn't think there was a read-write lock on the board that I'd have to clear before connecting, but now it works.
