2024-04-26 06:48 AM
im using th nucleo-f446re board, and the st-link isn't there. Am i missing some jumper connection?
2024-04-26 06:51 AM
Check other cables, check other PC USB ports.
2024-04-26 06:51 AM
2024-04-26 06:52 AM - edited 2024-04-26 06:53 AM
Open Device Manager and turn on the computer sound. When you connect and disconnect the USB cable, is there any sound or update in Device Manager?
2024-04-26 07:03 AM
yes both a sound is being made and the board is shown in device manager
2024-04-26 07:25 AM
2024-08-11 08:11 AM
According to the User Manual, LD3 shows an overcurrent event (which in your case is red)
