ADXL345 accelerometer using SPI and USART for sending to serial monitor
Shaku
Hiii everyone!!!! i want to use ADXL345 as accelerometer by using spi communicatiton and debug and display the value of respective axis in any serial monitor. Please give me the respective code for my guidiance.
Andrew Neil
Evangelist III
You need to write your own code - this is not a free code-writing service!
If you want someone to do your project for you, try somewhere like:
https://www.fiverr.com/categories/programming-tech/electronics-engineering/embedded-systems-iot?ref=platform%3Astm32
So you have two things to do there:
  1. Communicate with the ADXL345 using SPI;
  2. Communicate with the "serial monitor" (using a UART)
I would suggest that you start with using the UART to send stuff to a terminal - as that will also be useful for debugging.
You can find plenty of examples of using both UART and SPI on STM32 from ST and 3rd parties.
For specific details of how to communicate with the ADXL345, go to its manufacturer:
https://www.analog.com/en/products/adxl345.html
I'd worry about my job if ChatGPT can do it better than I can...
