NUCLEO-H743ZI default jumper position
suhfi
Senior
hello, could you please tell me where the default jumper wires be placed on the board h743zi2. quick response is much appreciated as i am in a hurry with the deadline. pictures of the board are much needed while answering.
There are no jumpers on the bottom. Only solder bridges.
The only jumpers on the bottom are connected on GNDs connectors as "spare"  jumpers for future use.
From the user manual of the board (Figure 1 and 2):
In any case, you need to check the user manual of the board for each default position: jumpers and solder bridges.
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
4 REPLIES 4
SofLit
You can see that in the image of the board's presentation page:
https://www.st.com/en/evaluation-tools/nucleo-h743zi.html
But you need to provide a description of your problem.
STTwo-32
Hello @suhfi
You need to follow this getting started table:
together with the board picture:
Best Regards.
STTwo-32
okay, thank you for response.
it would be more appreciated when you send the photo of the back view also of the board. The problem is i am not sure if i dropped some jumpers or not.
