nucleo-h563zi ST-LINK not found
ypearsonai
I plugged in a new nucleo-h563zi, but the st-link wasn't found. The demo blinky code is running fine.
LD6 is solid green and
LD4 is slow blinking forever
On Ubuntu 22 LTS
Any ideas?
>>Any ideas?
Plugged into the North End USB?
Data, not charging, cable?
Drivers loading? Recognizing VID/PID for MSC, CDC/ACM and ST-LINK debugger?
4 REPLIES 4
>>Any ideas?
Its the USB-C cable connected to CN1. all jumpers set to default
If I plug in the board to my PC, there is no new USB/st-link device that pops up
So no new VID/PID, pops up
Hello @ypearsonai
As @Tesla DeLorean suggested, try using a USB type-C Data Cable and not a charging cable that is only able to power the board, but it is not able to transfer the data from your PC to the board.
Best Regards.
STTwo-32
ypearsonai
The cable was bad :|
