Not able to print through STLINK on cubeIDE serial Terminal (Not finding Serial Terminal on CubeIDE)
PShar.11
(Not getting Serial Terminal on CubeIDE)
2 REPLIES 2
KnarfB
Principal III
You're right. The output used to be in the console window. But, I can open the serial port in a separate terminal prog (TeraTerm, PuTTY, minicom,...) and see the output. Actually, I like that debugging agnostic behaviour.
Pavel A.
Evangelist III
That's the Eclipse ... :(
In a Console, click on NEW icon on its menu bar -> Command Shell console -> Conection type: Serial port.
-- pa
