2025-02-01 7:17 AM
trying to send array below. The '0x00' part is not received in terminal, see image below.
char binary_data[] = {0x01, 0x02, 0xAB, 0x00, 0xCD};
HAL_UART_Transmit(&huart5, binary_data, sizeof(binary_data), HAL_MAX_DELAY);
How can I get this to work?
2025-02-01 7:32 AM
Change the terminal emulator program. The data is received, then ignored by your terminal.
2025-02-01 7:32 AM
2025-02-13 9:14 PM
Thanks gbm, it was indeed the Terminal program. Did not help that my intital data transfer was wrong so the GPS did not accept the message.
