2019-12-18 9:25 PM
Not able to print through STLINK on cubeIDE serial Terminal
(Not getting Serial Terminal on CubeIDE)
2019-12-18 11:30 PM
You're right. The output used to be in the console window. But, I can open the serial port in a separate terminal prog (TeraTerm, PuTTY, minicom,...) and see the output. Actually, I like that debugging agnostic behaviour.
2019-12-19 12:42 PM
> Not finding Serial Terminal on CubeIDE
That's the Eclipse ... :(
In a Console, click on NEW icon on its menu bar -> Command Shell console -> Conection type: Serial port.
-- pa
