2022-10-05 02:01 AM
When I try to debug the standard led toggle example I get the No ST-LINK detected message,
Board: STM32H7A3ZIT6Q
Host: Windows 11
IDE: STM32CubeIDE 1.10.1
When I open Device Manager and connect the board to USB there is not one extra device detected. I also tried to add the device drivers manually by using the Device Manager and opening STM32CubeIDE\drivers\STLinkUSBDriver.
2022-10-05 06:12 AM
STM32H7A3ZIT6Q that's a CHIP not a BOARD
You have a NUCLEO-H7A3ZI-Q ?
Poor quality cable
Charging cable
Policy or lock-out of MSC type flash drive on PC/LAPTOP
2022-10-05 06:12 AM
Poor quality cable
Charging cable
2022-10-05 07:27 AM
Thanks for your response. You are right, it is a NUCLEO-H7A3ZI-Q board. And guess what, it was a crappy cable.
Thanks again.
