New with STM32H7
‎2024-03-06 04:56 AM
Hello community!
I'm trying to start a project to test a new board Nucleo-H755ZI-Q, but i don't now how dual nucleo works and if is a board problem, code problem or a debug config problem.
Follow some ST docs tutorial or Youtube tutorial give the same error: The CM7 and CM4 debug open, but if i click on run debug, the project debug close and cube IDE back to the code editor.
Here is the clock config print:
Clock config page 1
Clock config page 2
Here is the pinout config:
pinout config
The code CM7 and CM4 is just LED blink on infinite loop:
/* CM7 code */
while (1)
HAL_GPIO_TogglePin(LD1_GPIO_Port, LD1_Pin);
HAL_Delay(250);
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
/* CM4 code */
while (1)
HAL_GPIO_TogglePin(LD2_GPIO_Port, LD2_Pin);
HAL_Delay(500);
The Debugger CM7 config:
CM7 Debug page1
CM7 Debug page2
The Debugger CM4 config:
CM4 Debugger page1
CM4 Debugger page2
Startup config:
CM7 Startup
CM4 Startup
If someone has a complete exemple with IOC and code to blink leds on Nucleo-H755ZI it can help me so much.
- Labels:
STM32H7 Series
‎2024-03-15 07:06 AM
Hello @victorsj ,
Could you please try to uncheck the ST-LINK S/N in the Debugger configuration:
Please make sure in "CM7 startup" that the "Download" of "Debug\agora_vai_test_CM4.elf" is "true" as shown in the below figure.
Please make sure in "CM4 startup" that the "Download" of "Debug\agora_vai_test_CM4.elf" is "false" as shown in the below figure.
I tested your project using Nucleo-H755ZI-Q and STM32CubeIDE1.14.1 based on this video Dual Core Debugging on STM32H7 with STM32CubeIDE and it works correctly.
I hope this help you!
Kaouthar
‎2024-03-11 02:26 AM
Hello @victorsj and welcome to the Community :),
Which STM32CubeIDE are you using?
Are you following Getting started with projects based on dual-core STM32H7 microcontrollers
in STM32CubeIDE application note?
This application note describes how to get started with projects based on STM32H7 Series dual-core microcontrollers in the STMicroelectronics STM32CubeIDE integrated development environment. For that I recommend you to take a look at this application note and precisely section 3 Debugging.
May this post can help you.
Thank you.
Kaouthar
‎2024-03-11 05:08 AM
Hello!
Thank you for your reply.
Yes, i followed this application note to debug with GDB server and to debug with open OCD too. The two ways don't work yet. I did exactly how this video tutorial show too.
The Cube IDE is STM32CubeIDE 1.14.1
Hello @victorsj ,
Kaouthar
‎2024-03-29 05:37 AM
Hello @victorsj ,
Has your problem been solved?
If you need further support, please do not hesitate to update the post :).
Thank you.
Kaouthar
