2024-08-20 07:54 AM
I am working with B-U585-IOT02A.
In all example project using NetXDuo stack tcp/ip (web server, Azure Iot Hub, ecc. ecc.) the communication with wifi mxchip is performed by SPI using IPC -HCI command protocol.
I haven't found documentation about command accepted from SPI by MXCHIP module.
I need to know what command are received by mxchip wifi, because they are not standard AT command, and I need to develope a project with STM32U585 with a different chip wifi.
Several other wifi chip accept only AT command, and I need to analyze the difference and the structure of sample projects.
Best Regards
Fabrizio Beltrandi
2024-08-20 08:04 AM
@FBelt.1 wrote:using NetXDuo stack tcp/ip ... I need to develope a project ... with a different chip wifi.
Perhaps it would be easier to just find a WiFi module supported by NetXDuo ?
2024-08-20 08:07 AM
@FBelt.1 wrote:I haven't found documentation about command accepted from SPI by MXCHIP module.
There's a company contact given here:
https://www.st.com/content/st_com/en/partner/partner-program/partnerpage/MXCHIP.html
See also: https://www.mxchip.com/en and https://www.mxchip.com/en/about-us/contact
