2020-08-24 02:05 AM
I'm designing an interface board with a STM32F469I-DISCO board, and I would like to know the distance between holes and Arduino connectors (CN5, 6, 7, 8), in order to perfectly fit my interface board with the discovery board.
The only drawing i found was in the UM1932 document, page 26/30 : https://www.st.com/resource/en/user_manual/dm00218846-discovery-kit-with-stm32f469ni-mcu-stmicroelectronics.pdf
But it doesn't show the precise position of CN5, 6, 7, 8 on the board.
Thank you for your help
2020-08-27 03:15 AM
You have the gerber files there : https://www.st.com/en/evaluation-tools/32f469idiscovery.html#resource
You can try to use a gerber viewer, usually they have a "measure tool"
2020-08-27 03:15 AM
