2024-04-11 07:45 PM
Hi
I use STM32 NUCLEO-H743ZI2 development board for my project.
I'm considering purchasing electronic components for the first time, and I would appreciate a recommendation for an X3 crystal that could be used in this situation.
Additionally,
My board is currently in this state,
and I plan to solder as described in the following diagram.
Thank you very much for your guidance.
2024-04-11 09:06 PM
Hello @HMsDobby2 and welcome to the ST Community 😊.
For a recomendations about the X3، i suggest you to take a look at the bill of material file of your board. You will find the recommended part.
Best Regards.
STTwo-32
2024-04-11 09:06 PM
Best Regards.
STTwo-32
2024-04-14 09:48 PM
Thank you! However, can I just solder using the method I described? I'm a beginner and want to make sure.
2024-04-17 06:16 AM
Yes I confirm.
This is based on the schematics:
2024-04-17 06:02 PM
Thanks for the detailed responses!
