Hi..... I have stm32H7 and st-link_V3. Linux operating system.
MTS
/home/i/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32CubeProgrammer: line 4:  3947 Aborted                 (core dumped) $DIR/jre/bin/java -Djdk.gtk.version=2 -jar $DIR/STM32CubeProgrammerLauncher
this is the output I get to the terminal after the crash of the STM32CubeProgrammer. I have tested various versions of libusb, as well as Ubuntu 18 and Ubuntu 20. The result is always the same.What should I do to make STM32CubeProgrammer work on Linux? Is it possible?
7 REPLIES 7
MTS
tell me how to flash stm32H7 in the Linux console using st-link_v3?
MTS
STM32CubeProgrammer collapses from any action in its menu.
MTS
Ubuntu 18 and 20
MTS
:smiling_cat_face_with_heart_eyes: the board was determined in STM32CubeProgrammer under Linux
CubeProgrammer appears to be increasingly sensitive to problems communicating with the target processor. It just crashes with no explanation. Do you have a Nucleo you can try first?
MTS
STM32CubeProgrammer saw the developer's board. now STM32CubeProgrammer does not break. If there are any successes in the work, I will let you know
MTS
:two_hearts: ok;p
