I am using stm32f042g6u6 in my design,
Also i am using Keil uVision5 ide, Debugger : stlink v2
The problem is debug is not working in my circuit, controller is detected successfully,
i cant figure out the reason exactly, need your inputs .
‎2022-02-05 11:32 PM
‎2022-02-06 12:49 AM
There is a Getting started with STM32F0x1/x2/x8 hardware development with ref. schematics. How does your desing look like?
hth
KnarfB
‎2022-02-07 8:39 AM
Also, make sure that the SW clock frequency set in Debug settings is 1..2 MHz (The default value may be too high).
‎2022-02-07 8:49 AM
like schematic everthing is same still facing same issue.
‎2022-02-07 8:50 AM
This is our second version first version is working fine ,
In new one we are facing issue.
