2021-11-11 03:00 AM
2021-11-11 06:47 AM
Hello @Kp.1 and welcome to the Community 🙂
Which CubeProgrammer version used ?
You can try to connect in "under reset" mode, and check your USB cable, connectors.
Imen
2021-11-29 10:53 AM
Hi @Kp.1 ,
Were you able to resolve this issue ?
Please share the final solution you found and mark the reply as Best answer.
If you still have issues, please share more details to your post in order to help you.
Imen
