Failed to read registers from target
Morpheus
When loading my code onto the STM32F407 board, I encounter the errors "Target is not responding, retrying..." and "Failed to read registers from target" in the Console window. I have investigated the issue but have been unable to find a suitable solution. You can find the console and debug configuration screenshots attached. Can you help me?
Morpheus
It seems that there was an issue with the code I wrote, my friend. I had created a small library to toggle an LED on and off. I think I made a mistake while writing the library. When I replaced the code with a simple LED on/off operation, the board worked without any problems. However, I thank you very much for your feedback.
3 REPLIES 3
Imen.D
Hello @Morpheus,
Try Connect Under Reset mode.
Could you please provide the debug log for more analysis?
Imen
Imen
Morpheus
Really glad to know you overcame this problem
Thank you for the update you provided and please allow me to close this thread.
Imen
Imen
