Fail to program STM32F413 using ST-Link Utility (Sector 1 is erased automatically)
Stefan W
Posted on April 12, 2017 at 13:56
I want to program the STM32F413 with the ST-Link Utility (CLI and UI has the same issue). We have two hex-files. One for the bootloader in the first sectors and one for the firmware in other sectors. Of course no overlapping. Programming always fails. The ST-Link Utility does not report any errors, but when checking the memory after programming both files, sector 1 is always erased. After loading the first hex-files it looks fine, but after loading the second, it is reset to all 1. The other sectors are all okay.
Not an alternative for us, but I also tried to put both hex-files into one. This does not work either.
Programming the controller with OpenOCD works fine.
To reproduce the behavior:
  • Connect to a STM32F413 via ST-Link Utility v4.0
  • Set the values of the following addresses to zero: 0x08003FFC, 0x08004000, 0x08007FFC, 0x08008000
  • Program a simple hex-file to another sector (like test.hex in attachment)
  • Check the values at the addresses above
In my case the values in sector 1 (
0x08004000 and 0x08007FFC) are reset to all 1. The values outside of sector 1 (0x08003FFC and 0x08008000) are still set to zero.
Here some version information:
STM32 ST-LINK Utility.exe   v4.0.0.0
STLinkUSBDriver.dll             v4.4.0.0
ST-Link_CLI.exe                   v3.0.0.0
Firmware Version:                 V2.J27.S0 STM32 Debugger
Any ideas? Could someone please try to reproduce this problem?
#stm32f413vg #stm32-st-link-utility
13 REPLIES 13
Stefan W
Posted on June 01, 2017 at 09:41
Is anyone already using the 413 and can try to reproduce this please?
I found another, easier way to show this behavior. Just connect to the controller with ST-Link Utility and erase the chip.
Now change values in the memory browser directly. Each time you change a value, all value in the range from 0x08004000 to 0x08007FFF are reset to 0xFF. When changing a value in this range, only the currently changed value is set, all other are reset to 0xFF.
Posted on June 01, 2017 at 10:46
Ticking 'Skip flash erase' in the dialog which opens upon starting programming won't help?
I can't see a way how this could not work. How exactly did you merge the two hexfiles?
Posted on June 01, 2017 at 11:19
Thanks for your reply.
No. This does not change anything about this strange behavior.
First I merged the hex-files manually with a text editor. But I also wrote both hex-files via OpenOCD into the controller and then stored the memory with the st-link utility in a hex-file.
Posted on June 01, 2017 at 11:27
Okay so you problem is that you manually edit the content of data-to-be-programmed directly in the St-link Utility, correct?
Can't you edit them elsewhere and then load the edited file and program it without further editing?
I don't say it's not an error in STLink Utility, just trying to find a workaround.
Posted on June 01, 2017 at 11:58
No. I do not want to edit data manually. It was just a way to reproduce the problem.
I just want to program two hex-files in two separate memory regions of the STM32F413 with the ST-LINK CLI.
And my problem is that the memory from 0x08004000 to 0x08007FFF seems to be erased during or after programming.
Posted on June 01, 2017 at 13:42
And do either of the .HEX files touch that sector at all? You should validate that they don't.
Posted on June 01, 2017 at 14:15
The first HEX-file covers this sector. After programming only this HEX-file the content looks proper (no FF).
But after programming the second HEX-file, which does not touch this sector at all, or after programming the merged HEX-file, this sector is reset to all 1 again.
I know that this does not make much sense. It would be very helpful, if someone could try to reproduce this, so that I can see, if I am doing something wrong or not.
Posted on June 01, 2017 at 14:29
Not sure if this is an option, but Segger offers a JLink firmware for STLink devices.
And my experiences with Jlink are nearly all positive. Especially it proved clever enough not to touch unchanged Flash sectors.
Stefan W
Posted on June 02, 2017 at 09:32
It seems as if the ST-LINK Utility erases Sector 1 on nearly each action like direct write to memory or calculating memory checksum.
I am still looking for a solution, but I finally found a workaround, that could work for me. Instead of programming the hex-file for the bootloader and then the hex-file for the firmware, I program the firmware first. So the programming of the bootloader and of sector 1 is the last action performed by ST-LINK CLI. This way sector 1 is still written after the whole programming process has finished.
