Can't Debug Using ST-Link
‎2022-03-07 08:47 AM
‎2022-03-07 08:49 AM
I have a project based on the STM32L496, built using IAR. I am trying to do a download and debug in IAR, but am having trouble. When I attemp to connect, I get the following dialog in the IAR Debug tab:
Can anyone give me any info on the ELF/DWARF error? I'm not trying to use an external flash loader. Note: debugging using the ST-Link works fine for other targets (tried F205 and L432).
‎2022-03-07 08:57 AM
Did the code build properly? Show build log.
Is the code built for the 0x08000000 FLASH memory location, check build settings, check .MAP file.
Is the L496 board/platform actually viable? Custom board?
On the ST-LINK/V2 pin 1 or 2 need to have target voltage present, is it?
Can STM32 Cube Programmer see and connect to your platform? Does it report the target voltage correctly?
‎2022-03-07 09:16 AM
Code builds fine. The linker is set to place this at 0x08080000, as Bank 1 on my custom board is currently write-protected and can't be unlocked (posted about that issue separately). Can connect using ST-Link utility and detect target successfully, with correct voltage.
