2019-02-18 06:18 AM
Has anyone implemented their own firm ware. I can so far successfully retrieve the EPC number from a tag, however I'm struggling to get a valid RN16 and CRC combination when using the REQ_RN command. I would like to do this to be able to access the TID memory.
2019-04-03 12:38 AM
Yes I have managed to do this.
2019-04-03 12:34 AM
Hello Chris,
it seems you have solved the problem already?
Cheers,
B
2019-04-03 12:38 AM
