2024-01-28 2:21 AM - last edited on 2024-02-01 1:25 AM by willzhou
We have integrated the STWLC38 as receiver for our device. We want to know how to read the registers to know the status of charging, voltage and Current.
https://github.com/STMicroelectronics/STWirelessCharging-C-Drivers/tree/main
this gives patch update of firmware. We need configuration code as we are developing the firmware on Zephyr.
2024-01-31 12:45 AM
Please find this link https://github.com/STwirelesscharger/Python_FT260_ST_WLC
This use python and FT260 dongle, for MCU I2C driver is same.
2024-01-30 11:14 PM
Hi
about the status of charging, voltage and Current. i will write some example code, and put to
Please give us sometime to write example code.
2024-01-31 12:45 AM
2024-11-08 2:46 PM
Hello Will,
My company is switching to use stwlc38 wireless receiver, and we would like to configure the chip supporting 15W. which code I should program in the chip, BBP or EPP or BPPEPP?
I would like to send charge-status (proprietary packet) to the wireless transmitter, so that the transmitter could identify which device it is charging to.
Look forward to hear from you.
