2023-11-09 10:17 PM - last edited on 2024-06-09 6:37 PM by willzhou
Looking through the data sheet for the STWBC86, there doesn't appear to be a way to write to the FTP (Few Times Programmable) memory, nor save individual configuration register values over i2c.
Any register values are only written to RAM and lost upon reboot... No worries, use the FTP memory for the config, but there doesn't appear to be a command in the data sheet to either:
If neither is possible which would be strange, what's the recommended process to program the chip at the factory?
2024-01-30 11:46 PM
We have update command line for download WLC chip fw, please check this link, thanks.
https://github.com/STwirelesscharger/STSW-WPSTUDIO
2024-06-09 3:11 PM
Your link is 404
2024-06-09 6:36 PM
