STWBC86 -> Writing FTP (Few Times Programmable) from header over i2c?
Looking through the data sheet for the STWBC86, there doesn't appear to be a way to write to the FTP (Few Times Programmable) memory, nor save individual configuration register values over i2c
Any register values are only written to RAM and lost upon reboot... No worries, use the FTP memory for the config, but there doesn't appear to be a command in the data sheet to either:
  1. Saving register values to the FTP Memory one at a time
  2. Using an address to write the header values for config / patch to (nor the process, if it differs from just writing all bytes to the specified address)
If neither is possible which would be strange, what's the recommended process to program the chip at the factory?
12 REPLIES 12
willzhou
We have update command line for download WLC chip fw, please check this link, thanks.
https://github.com/STwirelesscharger/STSW-WPSTUDIO
Your link is 404
Please find this attach file
